Ana içeriğe geç
Sony PlayStation 3 Move, 3D uzayda çalışan kablosuz bir kontrol cihazıdır. Move, oyuncu için oyunu canlandırmak amacıyla bir PlayStation Eye Kamera ile eşleştirilir. Onarımı basittir ve standart tornavidalar ile ayırma aletleri gerektirir. Hareket Kontrolcüsü Model Numarası: CECH-ZCM1U. Eye Kamera Model Numarası: SLEH-0048.
My controller is chagred but behaves as if it has no charge.
I have two move controllers and both were low on battery life so I charged them both on my way to bed. The next morning one worked and the other did not. When connecting to a power source it blinks quickly then goes dark. It does the same when I use it to try and power up the PS3. Where the working one flickers and eventually syncs giving a solid red light at the bottom of the controller the malfunctioning one will not. It flickers then goes dead without ever having turning on the PS3.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sounds daft, but have you tried hitting the reset button on the back? Similar to the six-axis controllers look for a little hole big enough for a paperclip and depress the switch for approx 10 secs. Then try and sync the device.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
that's the 1st thing I tried. No change! Is it possible that the battery has burned out from leaving it on the charger? The unit works fine while its plgged onto the usb but dies as soon as it's taken off. Battery doesn't seem to take a charge at all. Is it possible to purchase a new battery and replace it myself?
This is a great site! thanks for your help.
CC Pullen
tarafından
Yorum Ekle
Great!!
I hit the reset button and my Move controller start working again. I thought that the battery was malfunctioning.
Puan 0
Yorum Ekle
I had this problem with my son’s motion controllers. I took the batteries out and charged them separately using a bench power supply set to 4.2v and 1.3A maximum. Once the current had dropped below 700mA I reinstalled them and they now work normally. It appears that when the batteries are deeply discharged, the USB charging can’t cope and they need some more powerful charging. I hope that helps.
Puan 0
Yorum Ekle
Yanıtını ekle
Charles sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 4,149
