Ana içeriğe geç
Samsung Galaxy S8 Active, SM-G892A (AT&T) ve SM-G892U (T-Mobile ve Sprint) model numaralarıyla tanımlanabilir ve Ağustos 2017'de piyasaya sürülmüştür. Samsung Galaxy S8 Active, Samsung Galaxy S serisinin sekizinci nesli olarak Samsung Electronics tarafından üretilen bir Android akıllı telefondur.
How to change a battery?
how do i change a battery in an s8 active
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's a video tutorial on how to replace the battery.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi, Makayla! We will be adding in a replacement guide for the battery within the next couple of days. Although the video that Trevor posted (which we even used for reference while making this guide) successfully removes the battery, it does so with a metal spudger. This is a HUGE safety concern as the metal can puncture the lithium ion battery and can cause it to leak electrolyte fluid and make the battery go into thermal runaway (which can cause fires!). The battery is rather difficult to get up since it uses industrial grade adhesive on the back of it, but with the right amount of heat, you can soften the adhesive without raising a safety risk.
Puan 0
Yorum Ekle
Yanıtını ekle
MAKAYLA GOEN sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 901
