Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
No display and no backlight
Hi,
I’m have problem with my Early 2013 MacBook Pro it has no backlight.
Tried with knowing good display, no image at all on external display.
Backlight Fuse working fine, but there is small IC chip shows small burning
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
Can you give us some background information on what happened to the system to start with.
To be clear you don't see anything on the external display
tarafından
Suddenly display goes off and not respond
Tried reset SMC and PRAM
Checked Backlight fuse is ok with Buzzer
Tried with knowing good display issue still occurs ?!
Tried with External there is signal and working normally on external Display!
as you can see in pic , like burning on this crystal iC !!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Q3880 - SI8409DB - P-Channel 30 V (D-S) MOSFET
I think you need to dig deeper here as this likely was damaged by something else going bad on your logic board. I would get the schematics and board view drawings so you can properly diagnose the problem.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mohamed Ghaly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 324
