Ana içeriğe geç
16 Eylül 2016'da piyasaya sürüldü. Model 1660, 1778. GSM veya CDMA olarak mevcut / 32, 128 veya 256 GB / Rose Gold (Gül Kurusu), Gold (Altın), Silver (Gümüş), Black (Siyah) ve Jet Black (Parlak Siyah) renk seçenekleri.
Unable to activate iPhone 7
Restored iPhone 7 to iOS 12.1.4, the phone was stuck on the Apple logo and this is why I had to restore it. It restored successfully and got me to the Hello screen but iTunes says “The iPhone could not be activated because the activation information could not be obtained from the device”. On the iPhone itself it says “Unable to activate” “An update is required to activate your iPhone”. How do I fix this, what could be the problem?
Bu iyi bir soru mu?
Puan 16
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the iPhone via 3UTools and see if IMEI is present. You can also check this on the activation lock screen with the little circle information symbol at the bottom right of the screen.
It sounds like a baseband fault which means it’ll require micro-soldering to fix from a reputable phone repair shop.
Bu yanıt yardımcı oldu mu?
Puan 5
5 Yorum:
I do micro soldering. The IMEI isn't present in 3U tools. Only the serial number. And on the phone in the "i". There is no other information but the serial number only
tarafından Paylaş
Sounds like baseband PMU needs to be replaced as you've said it was stuck on apple logo and now this issue occurs.
tarafından Paylaş
What about the Baseband CPU next to the CPU?
tarafından Paylaş
Could be that too but you need to be careful removing it as it's near CPU that can only be reballed and not replaced as it's uniquely programmed to the phone for cellular service.
tarafından Paylaş
Any updates? I've seen two of these in the past 24 hours.
tarafından Paylaş
Yorum Ekle
iPhone 7 series phones have serious issues.There is two component stands for that problem.
1- BBPMU
2-BBCPU
If the BBPMU is damage that the solution but if the BBCPU is shorted no any solution.
Puan 2
1 Yorum:
No result
Same problem
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Dennis Warren sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 40
Her zaman: 14,934
