Ana içeriğe geç
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
20 Soru Tümünü görüntüle
Why is my display fainting, high brightness
This is what my display shows:
I’ve replaced the LCD, LVDS cable, LCD temp sensor.
I’ve also try plugging in an external monitor and it shows perfectly no signs of the faint image.
When I boot the system display it randomly shows a normal image sometimes but when it does, the system powers off or goes to sleep. I can hit the space bar to wake it up sometimes but once I restart the system, it goes back to the fainted screen.
Could it be the GPU still even though the external monitors shows perfect? Or the logic board? Power supply?
Bu iyi bir soru mu?
Puan 0
5 Yorum
To be clear the external monitor also has the same faint image is that correct?
tarafından
No the external monitor shows perfectly which is why I’m so puzzled
tarafından
Is it left alone for a long time
tarafından
Never mind it very old? Or needs a sweep in junk or caehe
tarafından
Yes it’s early 2009 A1225. Maybe so, i May need to reinstall OS
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
My bet would be a failing inverter or cable. There is no guide for replacing it the 24” but the on for the 20” should work just fine:
The Cable Inverter , power is Apple part #922-8856
There is a possibility the 24” does not have an inverter, you’ll have to look. In that case replace the inverter cable
iMac Intel 20" EMC 2133 and 2210 Inverter Replacement
Here the complete Apple Service Source on your machine:
http://tim.id.au/laptops/apple/imac/imac...
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Hey, thanks for the response. I've purchased the inverter cable and will be delivered Friday. I really think its the cable also because the A1225 model doesn't have a inverter, its on the LCD panel. The inverter cable is the only cable that hasn't been replaced that connect to the LCD so hopefully this will solve my issue.
tarafından
Im with the 24" Mac with no inverter facing this problem , what i could do?
tarafından
Yorum Ekle
I think you’re facing two issues which are interrelated.
First I would replace the PRAM battery which is located on the bottom right side of the logic board. Follow this guide to Step 12 iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Once replaced lets reset the display
  • Start by choosing Apple menu > System Preferences …
  • Select the Displays Preference Pane
  • Click the Color tab
As soon as you do the washed out screen should be gone.
Puan 2
3 Yorum:
How do i reset the display?
tarafından
The action I listed will do it auto-magically!
tarafından
hey thanks for the response. new battery was delievered yesterday and installed it and it still shows the faint image so i will try the inverter cable now
tarafından
Yorum Ekle
Yanıtını ekle
Corey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 9
Son 30 gün: 17
Her zaman: 815
