Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Soru Tümünü görüntüle
I need to replace this board but have no info on it
This board got wet and is corroded and I need to replace it but can find no info on it or part number. I don’t really want to have to buy a whole upper case to get one. Does anyone know what it’s called or have a part number for it or where to get one?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mayer - is this what you need? MacBook Pro 15" Retina (Mid 2015) Trackpad. Click on the right image.
MacBook Pro 15" Retina (Mid 2015) Trackpad Görseli
Ürün
$29.99
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
@danj looks to me like this board is attached to the trackpad. If I can just replace that board, the job turns into ten minutes instead of two hours and risking destroying the battery.
tarafından
As long as the trackpad its self is OK that should do it!
tarafından
Aren't the two cables soldered from trackpad to that board?
tarafından
@danj is @ben correct, are they soldered? I need to get this repair done today.
tarafından
I've never tried taking it off. I would first try the bad unit to see if you can disconnect them.
tarafından
Yorum Ekle
The board comes with the trackpad, it’s the controller of the force touch, you see those two flats are soldered.
It’s a mess to desolder, they melt too quickly, i tried is a nightmare..
Can you not just unglue the middle bit of battery cells and take out the trackpad?
Emil
Puan 1
Yorum Ekle
Looks like it can’t be done. After the board is unglued and lifted up there are ribbon cables (the clear ones)that run onto the trackpad that can’t be disconnected at the board. Will update later after I have full access to the trackpad
@danj
Puan 0
1 Yorum:
@mayer - Bummer ;-{
I thought the black cables is all you needed to undo.
tarafından
Yorum Ekle
Yanıtını ekle
mayer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 89
