Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 Soru Tümünü görüntüle
Display goes black when diagnostic test is launched
Every time I run a diagnostic test the screen goes black either in the initial quick test or in slow or extended test. I have to force restart it to get it working again.
I know this macbook had previous water damage but it was working fairly fine.
When I connect an external display (HDMI) the laptop restarts within few minutes and keeps restarting until I disconnect the display.
I tried SMC and NVRAM reset, same issue.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Your liquid damage has continued to corrode your logic board. You’ll need to take the logic board out and do a detail inspection looking for discoloration, green or white powder (salts). All of this will need to be cleaned off and as needed replace damaged components and traces.
Here’s the guide you’ll need to follow MacBook Pro 15" Retina Display Early 2013 Logic Board Replacement you’ll need a soft paint brush to first dust out the system and use a can of can’ed air to blow away the loose debris. Then get some cotton swabs and distilled water, don’t use tap! To wash the areas you find corrosion. Take detailed pictures of the areas you find.
You may end up finding you’ll need to just replace the logic board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Mario Ghantous sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 53
