Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Don’t see ‘charge battery’ screen once phone shuts down at 1%
Replaced battery a while back now, realised after it shuts down automatically once it gets to 1-2% charge, usually when i go to turn it back on without chargin, It shows a ‘plug charge cable in’ screen when you try and turn the phone back on, where as now it tries to boot again with the white apple logo screen.. gets about 10 seconds in showing the white screen on, and turns off again.. then if i try to turn it on again it goes into a boot loop with the white screen.. until i just get a flicker of white every few seconds.. then once i plug it in to a charger, it will white screen, turn off, then white screen and finally boot..
isn’t a major issue at all, just wanted to know what is going on, have tried a sleep button and home button reset (holding for 10 seconds until apple logo) as well as charging till 100% switched off, then home sleep reset again and running it down to 1%.. but still the same..
thanks for any help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Considering that this started after a battey change I would be inclined to think you possibly have pry damage around the battery connector, there is a swi filter Knoked off that commonly cause this,
Or secondly your initial issue may not of been tha battery. You may have a faulty tristar ic that can also cause the symptoms.
You will need to get this looked at by a board level tech.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Adam Bloor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 43
