Ana içeriğe geç
The JBL Charge 4 is a waterproof, Bluetooth capable speaker that additionally functions as a portable charger for smartphones. It is identifiable by its model number: CHARGE4S.
JBL Charge 4 speaker suddenly stops playing sound
My JBL Charge 4 bluetooth speaker was working fine until it suddenly stopped playing sound (even the ones it plays when it turns on, off, etc.). I don’t know what could’ve caused this since I don’t use the speaker on max volume. Speaker was charged and it connects fine, hasn’t gotten extremely wet either.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 7
11 Yorum
Jbl started having severe noise distortion and all of a sudden just stopped playing or making sounds at all. No power up or power down sound even though it seems to be connected to my phone. It is fully charged and brand new. Any advice?
tarafından
Same problem with mine, though no noise distortion before it fell silent suddenly. It was playing normally, then suddenly nothing. No power up or power down sounds, no connect sounds though it is connecting. Nothing. Pretty much still new. What’s the problem here?
tarafından
For the charge 4, the reset buttons changed to the play/pause button and the bluetooth button
tarafından
anyone got a solution for this? my Charge 4 just stopped producing any sound for no absolute reason, even the on/off sound is not played now, it connects normally but totally silent. factory reset didn't solve it. any help?
tarafından
Same for me - brand new and stopped producing sound out of nowhere - what a crap
tarafından
6 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Try powering on yourJBL Charge 4 first and wait for the LED indicator to turn on. Then try holding down the play/pause button and the volume up button up to 20 seconds and that should factory reset your device. Then try again and see if it makes sound.
I personally have a JBL Xtreme and I’ve had similar problem and factory reset fixed mine. Hopefully it works for you too.
Bu yanıt yardımcı oldu mu?
Puan 1
7 Yorum:
Tired that it didn't work for my charge 4
tarafından
Same problem, tried factory reset but still no sound. I need help
tarafından
Same for me, no sound....
tarafından
GREAT now my JBL won’t even turn on after doing those steps!
tarafından
Ok so this is the wrong combination for the Charge 4, mine also didn't reset and stopped turning on. I've finally found that to fix it again, you have to plug it in so the power lights up. Then hold Bluetooth and play buttons until it switches off. Then you can unplug and switch on as normal. That was an hour of stress I didn't need
tarafından
2 tane daha yorum göster
Yorum Ekle
Mine started working somehow, i pressed both the power and connect+ button together. While keeping these pressed, press the play and volume up. I somehow got mine back to life.
Try this again and again after putting into charge and removing it from charging.
Puan 0
1 Yorum:
Download the JBL Connect app. Pair the speaker with your phone. Select upgrade speaker.
tarafından
Yorum Ekle
Download JBL Connect app. Pair Bluetooth speaker. Select Upgrade speaker.
Puan 0
1 Yorum:
Worked like a charm although I don't understand how and why I was able to to upgrade my speaker off of my phone.....
tarafından
Yorum Ekle
mine did the same thing after falling. I took it apart and found the part the red arrow is pointing at was dislodged. I pushed it back in and it started working again but only when I’m pushing down on it. Not sure how to keep the downward pressure with glue.
Puan 0
Yorum Ekle
I had this problem and in my case solution was surprisingly stupid. Apparently I was connected to speaker on 2 devices. On pc, which was the music source, and on phone, which I used to browse reddit. Eventually I was stumbling on videos on reddit, and even without sound when you start looking at them, speaker stops playing sound on pc. So basically try checking for when exactly music stops and if it’s somehow related to what you are doing at the moment.
Puan 0
Yorum Ekle
My JBL charge 4 was playing music then all of a sudden it stopped playing it won't turn on but when I plug it in the power button light turns on but don't do nothing I tried pressing the power button plus volume up button and nothing
Puan 0
1 Yorum:
Did you ever get the audio working on your charge4? Mine has no audio also.
tarafından
Yorum Ekle
Yes is not up to a month
Puan 0
2 Yorum:
Yes and is not up to a month what do you think
tarafından
I did the reset thing
tarafından
Yorum Ekle
JBL charge 4, ic sound problem
Puan 0
1 Yorum:
Same problem.
tarafından
Yorum Ekle
If hard reset doesn’t work, disassemble it( check youtube) the take a look if one of the wires is disconnected. This was my case, works fine now. I imagine the assembly process is flawed if this problem is common. I never dropped my speaker or nothing too.
Puan 0
Yorum Ekle
Yanıtını ekle
SpeakerDude sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 56
Son 30 gün: 208
Her zaman: 48,446
