Ana içeriğe geç
The Dell Inspiron 1500 is a laptop computer designed for home-entertainment with a narrow border for a wider viewing area.
Turns on but the screen is black
Changed the battery, turns on but doesn't do anything. It's just a black screen.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
you can try following options:
  1. When you switch ON your computer, start tapping the "F8" key to get "Windows Advanced Options" (if boot menu appears, press "Esc" key and keep tapping the F8 key)
  2. Select the option "Last Known Good Configuration". If the problem still exists then follow the step 1 and this time select the option "Safe Mode". Check if you are able to boot into Safe Mode.
Or:
  • Reset BIOS (using battery or special jumper for resetting)
  • Re-heat graphics chip (you can use heat gun with about 400°C and heat, but not so long)
  • Remove RAM and try to start without them (after started, shut it down and replace them again, if still doens’t work, replace position, check, if “holders” are OK)
Or you can try options from DELL.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
kitcat1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 98
