Ana içeriğe geç
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 Soru Tümünü görüntüle
Do I still have a problem?
I had a problem with my 90 series Kenmore washer knocking loudly in spin cycle. With a burn smell to go along with that. I did some research then replaced the trany, clutch and coupling. Everything seems to be  working but I have a question.  Because of a loud pump I watched the cycle and don’t remember if during the drain cycle it should also spin.  If I open the lid during draining I see it is not spinning but if I press down the door switch it will start spinning.  If I leave it alone it will drain then after that spin.  Can someone tell me if I still have a clutch problem or is it good. Thank you
Update (03/03/2019)
Oldturkey03, thanks for the response. I’m going this route because when I comment to your response I get a message that my comment is kicked out as spam.
The model of my Kenmore 90 series washer is 110.26914691.
Thank you.
Bu iyi bir soru mu?
Puan 1
1 Yorum
@griegox this "it will drain then after that spin" is actually right. Does your laundry still drip water extensively after the washer stops?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@griegox
that would not be a clutch problem since it does spin etc. If anything it would be a program/timer issue. Let us know what your washers exact model number is. That way we could try and see what the timer sequence should be.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
No, it is rung out well. I get a good strong spin after it drains. I just was wondering why it doesn’t spin while draining unless I lift the lid then close it again or wait until drain complete then it spins automatically.
Ok, I will assume it is fine then. Thanks for your time.
tarafından
@griegox I'll keep on checking for more information and will post anything different on here. In the meantime enjoy your fixed washer. Remember "Repair is Noble" ;-)
tarafından
Yorum Ekle
Yanıtını ekle
Tony sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 117
