Ana içeriğe geç
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
197 Soru Tümünü görüntüle
How do I manually update a old Mac?
I have received an old Mac Pro G5 running Mac OS X Leopard, and have tried updating it to its newest possible form. When I downloaded Mac OS X High Sierra and even Snow Leopard, it says “Can not update” when I try to open the update file (Through USB).
By the way, I was connected to the internet by ethernet.
Bu iyi bir soru mu?
Puan 1
1 Yorum
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your Power Mac G5 uses a PowerPC 970MP (G5) CPU which is based on the RISC architecture. The Intel CPUs (Core2Duo, i3. i5 & i7) are CISC based architecture. The OS’s are very different! Your system can only support the older Mac OS-X. The early OS-X OS’s where in fact dual binary! So the RISC code would be loaded on your system and if you had an Intel system the CISC code would load in! It was very novel in its day.
Here’s an interesting nugget! The A chips used in the iPhone & iPad’s are RISC based! And iOS is a branch off of the RISC OS-X code stream.
So what to do here?
If your system is working tinker around with it. Just don’t get online with it as your system is not secure from all of the malware, trojans and viruses that are now floating out there in the wild.
If the system is not working or you want to get more out of it, then maybe you might strip the case down and install an Intel based logic board - Hackintosh within a Power Mac! Retro Power Mac G5 Hackintosh & Power Mac G5 Conversion
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
En Yararlı Yanıt
The highest system your machine will take is 10.5.8. Retail Installation DVDs can be found on eBay. Do a search for “Mac Leopard OS X 10.5” https://www.ebay.com/itm/Apple-Mac-OS-X-...
Be sure to get the Full Version, not the update.
Puan 4
Yorum Ekle
It’s because it does not support newer versions. You can check Apple’s website for list of OS’s supported devices.
Puan 2
Yorum Ekle
You need to keep up to date your mac. Update it manually or automatically. In automatic process you need an software or tool. In manual way choose Apple menu > System Preferences, then click Software Update.
You can clixk on Apple menu button where the number of updates are available.
Tip: You can also click the Apple menu—the number of available updates.
Puan 0
Yorum Ekle
Yanıtını ekle
William Sherman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 6,315
