Ana içeriğe geç
Acer Aspire U5 ev bilgisayarları için onarım ve sorun giderme bilgileri.
How to fix automatic repair loop?
So i turn on the computer, the acer logo pops up, then black screen then pops up again, says '“preparing automatic repair", and then shows up the blue screen that says “continue to windows 10, troubleshoot, turn off computer" ive used google and tried a lot of things, ive tried chkdsk thing, tried a lot with command console, tried usb but it wont let me boot it into the usb, ive tried restore, ive tried factory resetting it with both options, “there was a problem resetting your pc", ive tried startup repair too, idk what to do at this point, i got the computer 2 days ago and it started doing this yesterday, my pc is an ACER ASPIRE U5-620
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If it has only been a few days since you got the laptop, you should return it if you can. If you can not return it then you will have to go through a few cycles of the Starting Repair, Diagnosing and then restarting until you get a screen that gives you options to try other repair options. Since you have had the laptop for a few days then the best option to take is Reset the OS and it should reinstall the OS and act like a new install.
You can enable a USB device boot from the BIOS menu.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Deandre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 1,053
