Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Cranking but won't start
My car started running hot. Heater wouldn'twork either. My boyfriend replaced the water pump and the 2 themostats. He drove it down the road it didn't get hot. He shut it off and went to start it back. Wouldn't start only crank. So he replaced the crank senor wasn't it. Checked the plugs. It's getting fire. The fuel pump is coming on. He also took the air mass senor out still wouldn't start. I took it to mechanic he's had it for a week. He still don't know either. But keeps telling me he'll have it fixed the next day.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
the fuel pump coming on does not put fuel in the engine. The injectors are responsible for that. You need fuel, air and spark. Assuming the air filter isn’t totally blocked which would cause it to flood, and the spark is good, then the injectors are not working. Could be a timing sensor, blocked injectors or computer.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Check your security system
tarafından
Yorum Ekle
have your mechanic check your heater core..
Plugged heater core.
Update (03/07/2019)
or a faulty thermost that is sticking.. or installed backwards..
has your mechanic pressure tested your cooling system? and performed a leak down test?
Puan 0
Yorum Ekle
Have u tried the main
Puan 0
Yorum Ekle
Yanıtını ekle
Heather sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,660
