Ana içeriğe geç
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
case on the back of the screen is unglued
I dropped my Early 2009 MacBook Pro (don’t ask)
The case on the back of the screen seems to have come unglued at one corner. When I close the screen one corner doesn’t sit flush. You can lift the flap up enough to see the glue that was meant to be holding it together. Is there a way of re-glueing this back? Or any other suggestions?
Update
As you can see the screen is fine, still attached to computer, but the actual case or shell of it has come away.
When I pry it open a little it is possible to see where the glue was which stuck it down. Do you think I should try to glue it back? When I squeeze the lid down gently it fits back into place. If I were to glue it back is there a special glue I should use? A heat resistant one?
cheers
Bu iyi bir soru mu?
Puan 17
15 Yorum
thanks for your responses. still a bit unsure as it is the alluminium case on the back of the screen which has come away from the body of the screen... the glue inside looks like some kind of heavy duty araldite or similar. any ideas with this? the glass infront of the screen is actually ok, just the casing on the back....
cheers
tarafından
Can you take a close up picture to share? That would be helpful.
tarafından
Rupert what was the glue you used. My laptop is headed the same way. I hate to say but it is the same corner as yours too. Its not as bad yet but the black thing that covers the hinges is coming off and when I move the screen I can see where the glass is coming out of the housed aluminum cover.
tarafından
Well mine has held up since the post above dated Aug 18th
tarafından
I have the same problem in the same corner. I never dropped it, It's just been separating more and more as time goes by.
did the solution hold up?
tarafından
10 tane daha yorum göster
Yorum Ekle
17 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had the exact same problem and even took it to an Apple store, which said the cost of fixing it, given it was an older first generation unibody, made no sense. So, I was on my own.
Following suggestion I found online, i did the following:
1) Carefully took pix of everywhere there was glue inside the case.
2) Scraped out the old glue and noted its locations.
3) Sanded these locations lightly with high grit paper (600 I think). Vacuumed carefullly.
4) Treated these spots with a weak acid to etch them, I think I used vinegar.
5) Wiped it with rubbing alcohol to clean all residue and aluminum dust.
6) Using the photographs, I carefully applied JB-Weld Liquid Steel Epoxy to the same plces the glue was located, not just gooping it in, but not just putting a few touches of it either. Use the JB-Weld that takes the longest time to cure. (That is the strongest.)
7) Clamped it carefully, just enough to hold together, and make sure you don't let the case skew while clamping. Undue and realign it if needed. Left it two days.
Result: it worked. The case cover is back on, the screen is not coming loose, and it has held up 6 months now. Even getting very hot at times. It works.
NOTE: I do carefully baby the hinge, i don't just open and close it like when new, i continue to press down on the back and slowly open to minimize pressure on the hinge and reverse this when I close. Anyone who has the loose hinge knows what I am talking about. IT can't hurt to keep it stressed as little as possible. That said, I have forgotten one or twice and just slammed it shut or yanked it open. No problems.
Bu yanıt yardımcı oldu mu?
Puan 7
3 Yorum:
Have just followed these instructions using JD weld and crossing my fingers. will let you know how long it lasts. Jools, London
tarafından
Did you take the entire back of the screen case off before you did all of the scraping/etching and re-glueing, or did you carefully rework it in the small gap whilst the cover stayed on?
tarafından
Hi BabaRamDass, I'm experiencing the same problem as you, and was wondering if your hack still works or if the glue has failed now ? I imagine you had to disassemble the MB Screen to do this repair, dont you ? Thank you very much for sharing this nice solution !
tarafından
Yorum Ekle
En Yararlı Yanıt
The front glass is held on by an adhesive, much like the iPhone 3G front panel (if you are familiar). Using a heat gun or blow-dryer will soften the adhesive so it can be reworked. I would recommend softening the adhesive in this manner and then use some c-clamps around the affected area to hold it together while the glue resets. This is certainly no guarantee, but worth a shot if you want to avoid replacing the whole assembly. I would probably put cloth or padding of some sort between the c-clamps and the computer casing to avoid marring the case. Also, be careful to NOT over-tighten the clamps for fear of breaking the glass. Good luck!
Puan 8
9 Yorum:
http://www.apple.com/support/macbook-bot...
MacBook Bottom Case Replacement Program
Apple has determined that under certain circumstances the rubber surface on some MacBooks may separate from the bottom case of the system. MacBooks shipped between October 2009 and April 2011 may experience this issue.
Apple will replace the bottom case of any affected MacBook, free of charge, that exhibits the issue.
Bottom Case Replacement Process
You may choose from three options to get a replacement bottom case for your MacBook. In all cases, your MacBook serial number will be checked to verify that it is eligible for this program.
Assisted service
Visit an Apple Retail Store - Set up an appointment with a Genius.
Visit an Apple Authorized Service Provider - Find one here.
Self service
Order a replacement bottom case kit online.
You will receive a kit that includes a new bottom case, screws, a Phillips head screwdriver, and instructions for how to remove the current bottom case and install the new one.
If you feel comfortable with the self-service option, you can place your order via the web.
Note: If your MacBook does not exhibit any signs of this issue, no action is required on your part at this time.
Additional Information
If you believe you have paid for a repair or replacement due to this issue, contact Apple regarding a refund.
This worldwide Apple program does not extend the standard warranty coverage of the affected MacBook.
This program covers affected MacBooks for two years from original purchase date. Apple will continue to evaluate the service data and will provide further extensions to this program as needed.
tarafından
Hi, what you're referring to here is for the bottom case (this issue http://i.imgur.com/XvqTjoz.jpg) wheras Rupert Jarvis' issue is the EM209 issue: Ynt:DC-in or logic board?... Kind regards Shaun
tarafından
My macbook pro just started issue 9 months ago, it's a 2009. Any suggestions, it's the same issue as noted above
tarafından
Kirstin - Go to the like I provided and do one of the following:
Apple Technical Support - Contact us.
tarafından
I have this issue on the Macbook Pro late 2008 model. This model is nowadays classified as obsolete by Apple, does anybody have any advice on what I can do to get it fixed? Replacing the laptop for a minor hardware failure like this seems crazy when the device is capable of running the latest OSX so smoothly. Kind regards Richard
tarafından
4 tane daha yorum göster
Yorum Ekle
I note the procedure for removing the LCD involves heating the glue seam with a heat gun. It is possible that you could gently heat the affected area with a heat gun and with luck the glue soften and stick again. I would caution you this is just a theory--I don't know if it would work and you would need to be very careful not to cause further damage. Ralph
Puan 4
3 Yorum:
Here is the URL for the procedure I'm referring to. Please view before taking action. Ralph
MacBook Pro 13" Unibody Mid 2009 Front Display Glass Replacement
tarafından
You guys are too fast for me :/
tarafından
Dear Ralph (rj713).
Your theory is a good thought but unfortunately the glue that holds the hinge to the case is not the same as the glue that holds the glass on.
The glue that holds the hinge to the case will NOT soften and re-harden under the action of heating and cooling.
tarafından
Yorum Ekle
I had exactly the same problem. Thanks to this thread and similar ones around the web, I managed to fix it and it seems like it will hold. What I did was follow the these steps:
1) Shut the computer down completely and close the lid.
2) Lie it flat and carefully scrape away old glue on the exposed hinges.
3) Mix a full-strength two-part epoxy (it's stronger than super-glue).
4) Use a toothpick to carefully apply this to the exposed hinges.
5) Press the closed lid into it's correct place and wipe away any excess epoxy.
6) Using a cloth, two thin pieces of wood, and a loose wood clamp (or a heavy book) keep it pressed into position until the epoxy fully sets (up to eight hours). Make sure, of course, the clamp is only tight enough to hold it in place and no tighter.
A day later and it looks as good as new. I've seen elsewhere that you could just use super-glue and holding it together for 10 minutes, but this fix above seems more permanent.
Puan 4
2 Yorum:
Hi all,
I spoke too soon on my end... the left corner lifted again and now the right corner is up too. I can't close the lid without squeezing it shut in the back first. Had I enough time, I'd try to get Apple to fix it. But as is, I may go out and get the epoxy made especially for aluminum that's mentioned above.
tarafından
An update:
I finally had a chance to take this to an Apple store near Philadelphia, and they agreed to fix it... no charge. Even though it's out of warranty. I believe I heard the guy behind the counter say to a colleague "This is the third one..." while trying to get me the free fix.
Now, he may have meant the third busted Macbook. Or he may have meant that this is my third Macbook in a row, though I think I'm at number five or six. Either way, I was glad they did it and very grateful. I would have bought an iPad 2 on my way out of the store, had they not been out of stock.
So... it's worth a try, getting Apple to fix it. Barring that, these epoxy solutions -- maybe one special for aluminum -- are still probably a good idea, provided you do it right (I don't think I was).
tarafından
Yorum Ekle
i just glued it with an apoxi resin made for aluminium... seems to be fixed so hopefully it will hold! thanks for your time
Puan 3
2 Yorum:
Crossing our fingers for you!
tarafından
*UPDATE*
so it seems that i have tried three times with apoxi resin to fix this problem and three times the screen case just came off after about 6 weeks. the last time it came off, almost the whole case peeled off from 3 corners!! i decided to bite the bullet and take it to apple to see what they would say. turns out that because i still had applecare they just gave me a whole new screen!! they also replaced my whole motherboard and the track pad at the same time. they didnt care or even notice the bend in one corner where i dropped it which caused this problem. i would recommend to anyone with the same problem to do the same. i did scrape of all traces of the apoxi resin so they couldnt accuse me of trying to fix it myself and doing more damage. good luck all!
tarafından
Yorum Ekle
Hi All,
I've had exactly the same problem as outlined above, however my casing lifted on the right hand side and then 1 week or so later lifted on the left (basically exposing the whole back side of the computer so that I can see in under the case at the back and can see the reverse side of the screen). The laptop had never been dropped, always travelled in padded case and was (is) treated with love n respect...
I found yr fix and applied 2 part epoxy resin and clamped for 10 hours (or so - just to be sure... the only time the machine has not received love). It stayed solid for about a month and then lifted again on the weekend.
Has anyone else had both corners lift? Has everyone else found the fix to hold (beyond a month)? And does anyone have any suggestions??
Puan 1
1 Yorum:
An update for my issue as well - similar experience to Jackster... Apple Store in Australia agreed to replace the whole top section, no charge despite the fact that I was well out of warranty and no AppleCare. The repair guy said to me - "this isn't the first time we've seen this".
And, like Jackster, I was very, very grateful. I was especially grateful when he looked at the epoxy resin that was left behind (after I'd desperately tried to fixit myself) and said "you didn't try to fix it yourself did you?" (shaking his head no and giving me the Jedi mindstare) and I said "I didn't try to fix it myself". He said "I thought not" and 1 hour later I had a new top for my Macbook.
So my advice based on this small experience - get thee to an Apple Store regardless of warranty - preferably one connected to where you bought yr machine from so there is a personal relationship/ sales based relationship at least... if they look like they are not fixing it, well - it is clearly a design/ manufacturing flaw (not acknowledged yet by Apple - but if the glue isn't strong enough to hold the top case to the screen, it can't really be blamed on anything else except manufacturing or design).
If they look doubtful, maybe point them to this thread for the many other same problems from other Macbook Pro owners around the globe. It's definitely easier for them to fix the occasional one than force Apple to acknowledge a flaw which may see thousands upon thousands of upper body sections of Macbook Pros being replaced.
If your powers of persuasion don't work, then I'd go back to the epoxy. And after my experience don't ask me what kind... I clearly have no idea.
tarafından
Yorum Ekle
do those solutions really work which is best the aluminum poxy one? mine is lifting on the left side only sticks down when i press it, i was going to go the apple store but im terrified they are going to tell me i have to replace the entire screen which ive research is £400 being a student i dont have that kind of money! had my mac book pro a year and half now. never dropped it doesnt have water damage take special care of it so really don't understand why its doing this!
any help appreciated.
Puan 1
Yorum Ekle
I had same problem. It first started on the left corner and was getting worse with time. I always noticed that the left side was warmer then the right (probably melting down the glue). Anyhow I had to do something because this problem also made the image on the screen disappear on about one fifth of the screen on left. I read this forum and others, I decided to try with the epoxy glue. Went to the hardware store and asked for aluminium expoxy. I mixed the glue and using a wooden stick that I got at Starbucks, I put a fair amount of glue between the cover and the screen along the edge. I didn't have to undo anything as by the time I decided to fix the problem, I had almost 1/2 inch gap so inserting the stick with the glue was not a problem. I then closed the cover and aligned it correctly. Once this was done I put the laptop on the edge of a table and with a piece of wood going along the back, I used two vises to hold everything in place (not putting too much pressure). I let the whole thing dry for 24 hours. The next day, when I open up the cover, it was holding firm. I did all of this about a 2 months ago and it is still holding. My laptop is 3 years old and wasn't covered by any warranty. It cost me about $5 to fix it. I made sure to wipe off any glue so it doesn't even show that the laptop was repaired. And yes I have no more problem with the image. So I am quite happy with this solution.
Puan 1
1 Yorum:
G Toupin: Does it still hold up today your fix?
Regards
Morten Skoett, DK.
tarafından
Yorum Ekle
I had that same problem with my mac book pro A1286. my screen was separated from body,
I used different kind of glue after couple of days again separated, Then i found this 3M™ Windo-Weld™ Super Fast Urethane, This is usually used to bond vehicle windscreen to body, its did my job well. first clean both parts , remove old glue . when you apply glue use a clam or similar kind
of heavy object on top until its cure, i kept 24 hours ,
its a rubbery glue can withstand heat and vibration ,http://imageshack.com/i/ng8py1j
Puan 1
Yorum Ekle
LOL @ all the mess and then getting the free screen replacement :) But also this thread is awesome. Very helpful.
Question -- did you all pull the screen to do the repair? Or did you try it with the screen still connected? Did you clean the surfaces of old glue, rough it up a bit, before using the epoxy? Still can't believe they used epoxy. The screw holes should be part of the rear-cover mould.
Puan 0
1 Yorum:
Been going a month with my repair on one of these. Obviously that's not enough time to be iron clad -- but the procedure was to take the screen/back cover apart completely and get a good slathering of METAL epoxy in there (these are almost always grey/black once mixed, like JB Weld), clamp it down, and let it dry over a full weekend. Make sure you don't have excess epoxy sticking out of the top of the bottom side of the 'screen bracket' (as I will call it). The screen has to slip in under that. I was close, but had JUST enough room to slip the screen back in.
It's very solid so far, but who knows.
tarafından
Yorum Ekle
I am having the same problem. I've been checking into epoxy solutions and researching the 3M company site. I think the epoxy of choice for this job is 3M Scotch-Weld DP810.
What I've also been finding out is that exposure to heat affects the bond strength of a lot of glues. I think this might be the problem for those people without drop damage -- because the hinge is near a part of the computer that really heats up, over time the glue probably loses its hold because of the heat exposure. And it probably means this is a particularly weak point in the hinge, so that if you do drop, it's pretty susceptible to breaking.
Puan 0
Yorum Ekle
My problem looked similar and the frame was broken. I suspect thats always the case when the back comes off like in the picture above and here: http://www.mac-forums.com/forums/apple-n...
since apple only sells the whole cover with display and glass for the price of a used mac, I bought only the refurbished frame on eBay from top-best, realy easy and nice, from China.
to remove the glass is not very easy, and the exchange of the back also needs some study on youtube or here: http://video.answers.com/how-to-remove-t...
but its reasonable and I did not have problems
thank you all for help!
Puan 0
Yorum Ekle
first off it is not glue it is a special Adhesive made by 3M called 300SLE
DO not make the mistake of GLUING your case back together. First, take a blow dryer or heat gun if you have one. and on low move it back and forth in the area that has come unglued. then using your finger carefully press and hold the pieces back together. If you have a potato chip clip or other holder or sit a book or two on it with a pillow between it.
Look on ebay they sell the stripes of adhesive you need if that fail replace it if you can find a ifitit.com guide to doing that
Puan 0
1 Yorum:
Sorry Gary but you answered the wrong problem.
I think you mean 3M double sided tape 300LSE (Low Surface Energy), not 300SLE.
This double-sided tape is used to stick the glass back into the upper case. However this post is NOT about sticking the glass back into the upper case, it is about re-attaching the hinge anchor plates to the inside of the upper shell (case).
Thank you for your submission but you have answered the wrong question.
Also, 3M's 300LSE tape is designed for sticking things to Low Surface Energy plastics such as polypropylene and polyethylene, but neither the Mac screen (which is made of glass) nor the aluminum frame to which it needs to be attached are LSE plastics, therefore a Low Surface Energy adhesive tape such as 3M's 300LSE is NOT the best tape for the job. For more information about 300LSE and why it is not ideal for the job, do a Google search for 3M 300LSE and watch 3M's explanation. I suspect that an HSE (High Surface Energy) tape will be much better for sticking the glass back in.
tarafından
Yorum Ekle
I just got a hand-me-down from my mom with the same issue. Now that it has been a few years since any one posted on this, how has it held up? Should I try it or save the $400 to have a repair shop put a new display on?
Thanks!
Puan 0
1 Yorum:
It has been a while since anyone posted on this but I still have the same laptop all these years later and it still works like a beast! I have had to replace the whole screen assembly though as gluing it only seemed to be a temporary solution. It never seemed to fit as snugly as it did origionaly and the glue I used didn't last more than a few months.
After doing a lot of research about two months ago, I bought a second hand screen from eBay. If you are in the US there are quite a few to choose from (unlike in the UK Where I had to wait for one to be listed). You should be able to pick a on up in excellent condition for between $100-$250. I would say fix it yourself obviously as iFixit has a perfectly easy tutorial on doing it. It's important to buy the right screen though so make sure you know exactly what model you have.
It's worth doing because my laptop is now 8 years old and still runs all my music software perfectly and even works reasonably well on El Capitan!
Good luck.
tarafından
Yorum Ekle
Hi folks!
well, I'm in the same situation as everyone there. Spent some money to upgrade my Late 2008 MBP ( 8Gigs of RAM, Samsung SSD), and one day this huge trench on the hinge.
Did the glue trick. Worked 2 months. Did it again. Worked only 2 weeks. So kept it trenched, moving / opening / closing the screen very carefully.
Decided also to clean the fans ... and now I've got a nasty dust between the LCD and the glass (I know, my fault, I should have thought twice)!!!
So now it's time to replace the display assembly.
I have the opportunity to get a "fried NVidia" MBP 2010.
Would it be possible to use its display assembly? Found a topic on using a MBP 2009 display assembly, but not the 2010 one.
Or maybe I should try something on the MBP2010.
Any advice will be welcome. I love my Late 2008 MBP. Still a beast.
Puan 0
Yorum Ekle
I found that the broken screw is twisted in the assembly. Ones I bent it back forth a few times in an attempt to scrape the glue out …The screw/broken assembly just fell out and the screen self clamped shut and did not really want to open back up again. Going to use some Barge Cement (the old one) and doubt it will open again. It should sit snug like the right side and if not because seemingly something looks jammed I would bet its the broken screw. Gluing that would be like pining down a spring with glue. Make sure it snugs up by itself before any glue.
Puan 0
Yorum Ekle
To all. I bought a faulty Mac with this problem and I’m about to fix it using an epoxy resin glue. I won’t know how well it works for a few months but I’ll report back if I remember.
But for anyone about to attempt this repair job be aware that aluminum is a highly-reactive metal that reacts with oxygen very quickly and forms a very thin, nearly invisible layer of aluminum oxide on its surface that protecst it from further oxidation (the aluminum’s equivalent of rust).
However, and most importantly, the Al Oxide surface layer is very resistant to glues, and epoxy resin will NOT adhere to it very well. I tried it and found that I could peel the epoxy off the aluminum shell easily after 48 hours.
The aluminum surface needs to be properly prepared for the epoxy by sanding it down to clean shiny metal, then applying the epoxy resin glue very quickly afterwards. “How quick is quickly?” you might ask. I have not determined the time yet but by practicing on an old aluminum sardine can I found that if the cleaned surface is left for 24 hours before gluing the epoxy resin will NOT stick well. I am experimenting with gluing parts together within 2 hours of sanding and the epoxy seems to stick quite well within that time frame.
BEFORE attempting to repair a hinge carry out a test by trying to stick something to a piece of aluminum - like a sardine can, and see if you can peel the epoxy off easily with a knife. If it comes off relatively easily then your hinge repair will fail.
Update (01/14/2019)
A few peole have postulated that maybe the cause of the original glue coming unstuck was because they closed the case with their right hand and perhaps that twisted the top too many times and put more force on the right hinge (or the left hinge), thus causing it to break.
The real answer is much simpler. There was not enough glue applied to the hinge in the first place!
When I opened my Mac case I found only half a dozen small drops of glue on one of the hinges. Of the two surfaces that needed to have glue applied to stick them together only about 10% of the surface area had remnant glue on it.
The other hinge did have enough glue on it, but once the first hinge broke, the other hinge DID have too much "twisting" force on it and it broke away too.
So the real reason was just sloppy manufacturing by Apple.
Puan 0
Yorum Ekle
Yanıtını ekle
Rupert Jarvis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 206
Her zaman: 62,414
