How to disable Mac OS High Sierra Thermal Throttling?
Seem to be having kernal_task thermal throttling. Where CPU is throttled to 0.8GHz and fans run max. Issue is intermittent so only happens sometimes but it massively frustrating. All sensors are fine. Had previously SSD fitted but had stock HDD refitted to no avail. Confirmed that mac is not overheating. How would I disable the thermal throttling?
Bu iyi bir soru mu?
You talk about having replaced the HDD for a SSD did you install the OWC in-line thermal sensor when you did this?
What does diagnostics tell you?
DanJ tarafından
I did previouly but i have had stock HDD put back in. When imac plays up Apple Hardware Diagnostics says there may be problem with system management controller
Liam Boyle tarafından
Then someone damaged your system if they put back the original drive. If they just put anything else in then they forgot the in-line sensor.
What is the error message you got when you ran diagnostics?
DanJ tarafından
The sensor was definitely reconnected. No error, it just says 'there may be a problem with the system management controller (SMC)'
