Ana içeriğe geç
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
41 Soru Tümünü görüntüle
Every gear is drive
I have a 96 automatic 4 speed 4x4 ranger… I just replaced the gaskets and valve body and solenoids in the transmission along with filter. I have everything back together but the truck thinks every gear is drive. Why could this be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
It ended up being the gear selector valve, since it was a new valve body I never pulled out the gear selector valve and made sure it was aligned with the valve.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
It seems like an issue with Transmission. First verify the gear shifter is connected properly, and if possible attach images of the new work you did with the Transmission.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Problem is I never touched the shifter on the transmission. All I did was bought a new valve body for the transmission. With new solenoids filter and gaskets. New valve body came pre-assembled with gasket already on the inside. All I did was place the new gasket on the outside between the valve body and transmission. Bolt the valve body on the transmission, bolt up the servo cover , connect plugs for the solenoids power, bolt on the filter and then bolt up the pan. Put in fluid and then connect the battery ... Then I turned on the car and then have no gears besides drive. Park is drive reverse is drive...you get the point.
tarafından
Hey I am having the same problem with my 2001 Chevrolet s10 with every gear stuck in drive and I fixed the transmission myself as well but ran for a while so would you be able to go into detail about how you resolved the issue?
tarafından
Yorum Ekle
Yanıtını ekle
Charles Stewart sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 248
