Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Replacement battery no longer working
Last week I replaced a battery in the early 2013 MacBook Pro that our company has. After installation everything turned on and sounded great and the end user calibrated the new battery with no issues.
Fast forward to this week: User can’t use the laptop unless it’s plugged into the charger. System information shows that the battery is fully charged although it has 0 cycles and the Amperage is 0.
I’ve reset the SMC and PRAM and opened the laptop back up and the connections look good. Stumped at this point!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You probably got a bad quality battery. Try using ifixit’s battery. MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Replace a 8680 mAh battery compatible with MacBook Pro 15" Retina Mid 2012 to Early 2013 A1398 model laptops. 11.26 Volts (V). 99 Wh (Watt Hours). Battery model A1417. Görseli
Ürün
$79.99
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
That's where the replacement battery came from :-(
tarafından
So go to ifixit support because your battery is probably defected. If I helped you please accept my answer.How To Accept an Answer
tarafından
Yorum Ekle
Yanıtını ekle
Ashley Assink sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 51
