Ana içeriğe geç
My battery is not charging
Hi,
I bought a parrot rolling spider a few years ago. Now I found it again, but while trying to charge, I realised it didn’t charge… I looked for tutorials online but nothing worked… I also tried to plug the drone in and than add the battery also with no luck…
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you notice you battery getting weaker? If so this makes sense these batteries are not so grand and look for a battery replacement.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I just ordered a new battery... Thanks for your quick response!! You are the best!
tarafından
Where did you get the battery from
tarafından
Where did you get the battery from?
tarafından
Yorum Ekle
How much old your battery is?
Puan 1
6 Yorum:
I'm not sure but I just ordered a new one thanks!
tarafından
He rote in the description a few years
tarafından
Where did u get the battery from
tarafından
For srinivassai31 and others concerned; you can likely still charge an old battery. They get reluctant after sitting unused, but take it out, free of all contact, and very slow charge it for a long time. It might pump up just from that, but coaxing it along by repeating this with a little more volts each time..no more than half again its own volts, (=1½) to max at ¾ more added, will almost always get an old dead battery started again. Just watch the heat, and any swelling as signs you need to back off for awhile. Remember this is a percentage, and the smaller the battery the less added volts in a charge it can take. As example: a 12v regularly charges at 17.5v, which is half again its own volts.
tarafından
Hi, I bought the drone in 2016 and hardly used it for last few years. Now I have found that the battery has swollen. Please guide me how can I replace the battery.
Please note I am in India.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Maximilian Klein sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 56
Her zaman: 2,830
