Ana içeriğe geç
The SanDisk Cruzer Glide is USB flash drive with a retractable USB plug. It comes in a variety of storage capacities with a black and red plastic case for all models.
Flash drive shows 11 different usb drives
So when I plug in my flash drive windows shows up with 11 different error messages well the error messages are the but they like drive O and drive K and so on some please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
If you want to format it run in the command promp and right “DISKPART” then right “LIST DISK” then right “SELECT DISK K” that “K” that I rote is not rely what you should right it is just an example so whatever the letter of your flash drive is type that in instead of the K
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Usually you see that when you burn an IMG file onto the flash drive.
You can either delete the partitions manually via disk management which takes ages. Or clear the selected disk (diskpart lists them as disk numbers you can find number in disk management).
In command prompt as administrator you type diskpart then list disk, then select disk X (replace d with number), then type clean and then reinitialise disk in disk management.
This is if you don't need to backup the flash drive.
Puan 0
Yorum Ekle
Yanıtını ekle
Jen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 152
