Ana içeriğe geç
HP Compaq 8100 Elite, Where is the Front Panel Connector?
I decided to build an all used parts PC and try to get bang for the buck performance. Well I have everything but the front panel done. I cannot find the front panel connector. The motherboard is powered because there is a green light on the motherboard. Any help would be appreciated! Thanks!
Bu iyi bir soru mu?
Puan 1
2 Yorum
Hi @imjimjim21
Your question is not clear and I would like to know more
So are you still using the existing HP 8100 mainboard or another mainboard?
How about the computer casing ? are you still using the HP or new casing?
tarafından
@augustine Sorry about that, I am still using the HP 8100 Elite mainboard. For casing I am using the Corsair Carbide Spec-04 Tempered Glass. I have the board in the case and I looked up the orientation of what the front panel connectors go, but I do not know where to plug them in at:(.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Jimmy,
HP 8100 service manuals. The second one has a good photo. Zoom in and read the labels.
http://h10032.www1.hp.com/ctg/Manual/c02...
Page 7-8
and
http://h10032.www1.hp.com/ctg/Manual/c03...
To get the above all I did was search “HP 8100 Elite manuals”
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
I'm also having this problem with the 8100 elite I looked on Mike's first link and found out my motherboard is the 8100 elite ssf but when I look at mine P5 is the correct place
but on my actual board I have this
I have this?
7 by 2 minus 1 on the manual but only 5 by 2 minus 1 on the board. Any ideas.
Puan 0
2 Yorum:
Could you do the photo again only this time in focus?
tarafından
Hi, I have the same problem as you... have you solved it?
tarafından
Yorum Ekle
https://www.reddit.com/r/buildapc/commen...
Puan 0
Yorum Ekle
Yanıtını ekle
Jimmy Robertson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 49
Her zaman: 3,878
