Ana içeriğe geç
Model A1347. 23 Ekim 2012'de piyasaya sürüldü. Core i5 veya Core i7 işlemci. Apple Fusion Drive.
Power Supply voltage test
I have an Mac Mini (Model A1347) that won't power up. I want to test the power supply (ADP-85AF) but cannot find the output voltage values anywhere on the internet.
I would be happy to post a 'technique' article showing people how to access and test the power supply in this model if someone can help me determine their proper output values and connector pins.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Pretty sure 12vdc 7.1, as for connector pins…. I have no idea. I'll do some digging.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here’s what I found when testing two of these power supplies. The right 4 pins, when viewed from this side, output 12VDC in relation to any of the 6 left pins. (see image)
Resim
Bu yanıt yardımcı oldu mu?
Puan 2
5 Yorum:
@wattmagner you are correct 4 wires on the left in your orientation are negative1; 4 from the right are positive the center wire is not connected.
tarafından Paylaş
@oldturkey03 / @wattmagner - your multimeter 1 probe contacted 1 wire/contact in the (red text group/above image) and the other 2nd probe contacted 1 wire/contact in the (white text group/above image)?
if one probe accidentally touched two contacts at once (in white or red group) would that short out the PSU? a friend with some electrical background said i have to find a ground for one probe then ONLY touch ONE contact say in the red group. if i accidentally touched two red group pins would could short out PSU.
do u have a technique to touch only one pin?
thank you!
tarafından Paylaş
@rasberry it is of course always a bad idea to cross points but I do not see how or why it would shorten things out. Anyhow, the pitch between the contacts is wide enough to really not worry to much about it. Your probes should not be that thick. If they are, use smaller probes. Always good to have a variety of test probes for your meter.
tarafından Paylaş
Thanks for this valuable information. I was able to determine all 4 pins were delivering 12VDC nominal. but my Mac mini still won't power up. I followed the recommendations to swap out the SSDRAM ( no help), test the battery (2.78vdc0 and test the power with (also no help). I'm wondering if there is additional troubleshooting recommendations or a way to load test the power supply. thanks again
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Marcio Bernardine sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 1,747
