Ana içeriğe geç
Replacing glass screen & True Tone function
I cracked my phone yesterday, which normally wouldn’t have been a big issue but the crack is located over the front camera which distorts the lighting in pictures. I don’t think the LCD display is damaged and that only the glass part needs to be replaced. However, I did some research and found that True Tone disappears if you get it repaired by a third party (non Apple). Is that still an issue?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you have access to an Ambient Light Sensor programmer, then you can copy over the settings from the original screen to the replacement one. Otherwise, you may want to have this done by an independent repair shop or by Apple in order to retain TrueTone.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
The repair shop I’m planning to take it to isn’t an “apple authorized” place, however. Would that still disable True Tone?
tarafından
Yorum Ekle
Yanıtını ekle
Smm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 840
