Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
iPhone 7 ear speaker crackling static sound
My iPhone 7 ear speaker sound crackling
i replaced the audio IC & checked with another speaker still problem wasn’t solved
and also headphones not recognising
bottom speaker & microphone working fine
what I need to repair to fix this issue
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Did you touch this part iPhone 7/8/SE 2020/SE 2022 Earpiece Speaker if you did that can damage it so you would need to replace it.
iPhone 7/8/SE 2020/SE 2022 Earpiece Speaker Görseli
Ürün
$11.99
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
yes, after replacement also problem was wasn't solved
tarafından
So I see you changed every thing in that area that works for the earpiece speaker. Now I am assuming that the is some dirt In the ribbon cable that connects it to the logic bored. Take a tooth brush or something similar to that and clean the ribbon cable and the part where the cable connects to, which is on the logic bored.
tarafından
Yorum Ekle
Change and check the earspeaker this may solve your problem.
Puan 0
1 Yorum:
I already changed speaker but still problem wasn’t solved
tarafından
Yorum Ekle
Yanıtını ekle
feroz_khan77874 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,647
