Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
system will not run correctly following new HDD installation
i power my ps3 up after installing new hard drive, and the screen says that "no applicable update data was found. Connect storage media that contains update data of version 3.66 or later, and then press START and SELECT buttons at the same time"
where do i go next? i have all my previous data backed up on a WD 500GB usb hard drive.
what should i do next?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Neil Phillips, this is what I found here "Did you get the update file from the link below that says 3.66? IF you did, that's not the correct version, they updated the pages, but didn't update the link.
And since your PS3 apparently already has 3.66, that file is 3.65 and will get you nowhere.
Use this link to download the correct version, 3.66, and give it another shot.
http://dus01.ps3.update.playstation.net/...
and here is more info. I am certain once you get the correct version you will be back in business...good luck
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I've tried this, I've attempted many different methods of securing this update to my PS3, however i still get the same error.
Puan 0
Yorum Ekle
Yanıtını ekle
Neil Phillips sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,431
