Ana içeriğe geç
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 Soru Tümünü görüntüle
Strange behavior after replacing USB port
After a while of use, my DS4 controller would not charge via the USB port. I purchased a USB port replacement, but found that the controller still would not charge, even though with the new part (as with the old part, in fact) the LED would light up for things like pairing and connecting via Bluetooth (though it would not light up orange for charging). Furthermore, the LED would only light up for the above scenarios when plugged in via USB.
Is this a battery issue? What am I missing?
I’ve used 70% isopropyl alcohol to clean some parts in the past, is it possible there is liquid damage?
Thanks very much for your help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
It could absolutely be a battery issue … if you have another controller that works swap the battery as a test … if it fixes it, then buy a new battery. It would be highly unlikely that the charging circuit failed while the rest of the controller still works.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I don't have an extra controller with which I could test the battery, but I do have a multimeter. How would I use this to test this issue?
tarafından
Yorum Ekle
Yanıtını ekle
choi.brandon.h sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 39
