Ana içeriğe geç
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
Random Black Screen - Backlight Off - Panel On!
Posting a solution to my own question as I have not seen this answer on here before!
24” Cinema Display - Random Black Screen - Solution
24” Cinema Display, connected to iMac 27” as an external display and it works fine however at random points the screen on the Cinema Display will go black. Checking the screen with a torch I can see the LCD is still on and working as it shows my desktop.
I have hot corners with display sleep turned on so if I move the mouse to the corner the Cinema Display (while already black) properly sleeps, moving the mouse a second later causes the screen to come back on again fully lit.
The time between black screens can be totally random. Sometimes it works for weeks with no problem. Sometimes the black screens return within minutes or even seconds.
Troubleshooting:
Reset PRAM / NVRAM
Reinstall OS - same problem on Sierra, High Sierra and Mojave
Open the Cinema Display and clear out any dust
Reseat all internal cables
None of these fixed the issue. Sometimes they would appear to resolve it but the problem always came back.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Solution:
I finally found a post online where someone was saying that they suspected that it could be caused by a bad LED(s) on the LED strips inside the LCD panel itself and that they had success by replacing individual LEDs on the strip.
I decided to take an easier route and looked up the model number of the LCD panel on Aliexpress and found sellers offering full replacement LED strips for $20. I purchased the strips - they come as a pair of 2 that sit along the bottom of the display.
Fitting is straightforward albeit somewhat daunting. The LCD panel assembly needs to be completely dismantled in several stages by removing screws around the bezel, slitting the sliver sealing tape and then easing the surround off by prying the display out of the plastic surround.
Once removed you can then get at the area the holds the LED strips, they are held in with screws and adhesive tape. Simply replace with the LED strips you purchased online and then carefully put the display back together taking care to avoid dust getting in between the various plastic sheets that sit below the LCD panel.
The whole exercise takes about 2 hours in total. It is NOT difficult provided you go SLOW - however it does look terrifying when you have the entire panel lying in pieces on your workbench. It requires bravery rather than technical ability.
For what it is worth I also have an iMac 27” that had exactly the same issue and the above process fixed that as well.
I have had no more black screens on either display.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
@horatio20 - Answers is really for someone with a problem needing help.
Your efforts here are appreciated !! But, you need to make a guide! Follow this Contribute! That way it doesn’t get lost in the sea of questions!
tarafından
@horatio20 - You wouldn't happen to have a link or part number for these replacement LED strips, would you? I can't seem to find them on Aliexpress.
tarafından
Yorum Ekle
Yanıtını ekle
Horatio20 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 521
