Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Soru Tümünü görüntüle
iSight -> USB Pinout
Hi,
I am repurposing an iMac 7.1 (A1224) to external monitor+HDD+Speaker+Camera for my new Mac Mini.
I read that the camera cable is essentially a 5V/GND/Data+/Data- that I can solder to an USB cable easily. Now I am a surprised to find out that the cable is actually 5 wire, as seen on the picture below.
Thick Black - blue - green - white - grey.
I already gutted the iMac, can’t measure voltage on the cable. Can anyone help me out with a pinout?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi, I have your same isight and I successfully solved it in the following way:
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
the colors of the iSight may vary, mine had Black (corresponding to black USB) Grey (corresponding to red USB) and two Whites (corresponding to white and green USB). I used the first photo to compare wiring position tome my guessing.
As you have two white cables you'll have to make try & error, bad connection (of these two cables) make no harm as they are data ones.
Be careful with the other ones as the carry the DC feed)
tarafından
How do i connect them if i have grey purple white brown/orange and black? My imac is the a1312
tarafından
Yorum Ekle
ive done this before with a late 2009 imac which has the same connection, from what i remember one of the wires isnt needed when spliced to a usb cable and can be ignored
Puan 1
Yorum Ekle
The iSight camera unit connector is wired like this:
It offers dual mics, IR and camera which is why it has a few more wires
Puan 0
Yorum Ekle
If you have 2011 iMac 27 inch.
This is the connection for usb:
USB black cable to camera black cable.
USB cable red to camera blue(ish) cable.
USB cable white to camera green cable.
USB cable green to camera light gray cable. (look closely)
Puan 0
Yorum Ekle
Yanıtını ekle
Clue Less sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 1,950
