Ana içeriğe geç
Samsung Galaxy S9, SM-G960XU model numarasıyla tanımlanır. Mart 2018'de piyasaya sürülen, Samsung Galaxy Serisi'nin dokuzuncu neslidir. Leylak Moru, Gece Siyahı ve Mercan Mavisi renk seçenekleriyle mevcuttur.
My touch screen is unresponsive
While on facebook my touch screen just stopped working… The screen comes on and stuff like normal… But it just isnt responsive at all..
I tried almost everything.. Tried reseting it i tried booting it into safe mode…
But still nothing
Any other tips before i perform a factory reset.. Which i really do not want to do
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
Do you have any screen protectors installed? If so, remove them to see if anything changes.
tarafından
Have you ever had it opened before?
Highly doubt its software
is the phone damaged physically?
tarafından
The phone was never opened before
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
When the screen touches itself its called ghost touch. This happened when there is physical damage to the screen which calls for a replacement.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
I was hoping this isnt the :'( the phone is still new it never fell or went in the water im not sure if samsung will replace it either
tarafından
So go and ask samsung that's a good idea.
tarafından
Can it be a software issue like maybe cause I havent formatted the phone as yet and im praying thats the solution...because I mean the phone never fell when I had it with me and it has never been open it was in a cover and had a tempered glass from the time I got it
tarafından
Highly don't think so but I should not stop you from trying.
tarafından
Yorum Ekle
Try connect with USB-C/OTG reduction some mouse.... Try backup your data first on memory card... After hard reset can help.... Maybe.... But data you can
Puan 0
2 Yorum:
I am actually using a mouse will backup and reset pray its not any hardware
tarafından
the screen also started to touch itself recently
tarafından
Yorum Ekle
If it is new and if it's not cracked or water damaged then Samsung should be able to sort that out for u, just backup stuff u need first though
P.s did u remove the tempered glass u said u had on it and try it without that on???
Puan 0
Yorum Ekle
Unfortunately it’s likely not a software issue. If you said the screen is touching itself (Ghosting) then that likely means it’s a hardware issue with the screen itself. You may have just gotten a bad screen. If the phone is still under warranty then I would suggest you back up what data you need and claim the warranty on the device.
Puan 0
Yorum Ekle
Yanıtını ekle
Brentley Kyle Tikum sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 3,142
