Ana içeriğe geç
USB flash sürücüler (jump drive, USB bellek veya parmak sürücü olarak da bilinir) için onarım rehberleri ve destek.
Why is my USB device not recognized?
The system of my computer is Windows 10. When I plugged in my USB hard drive it just doesn’t turn out and shows that "USB device not recognized". I have upgraded all the drivers. They are up to date but still not working. What can I do with it?
Resim
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi, can you check the USB device from the Disk Management?
Way to check with these steps:
  1. Press Win Logo key + R and then type: Diskmgmt.msc
  2. Find your USB device there.
Give me the feedback, thanks.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
I have followed the suggestion and the device can be found already. Thanks a lot!
tarafından
Hi, if you can find the USB device there in Disk Management, that means the device is still working but corrupted due to some technical reasons. To fix this error, you can try to retrieve the data first from the USB device and then follow the steps with this link to fix: https://www.r-datarecovery.com/usb-devic..., leave me the feedback here, thanks.
tarafından
I've fixed the problem with your suggestion. The software is so convenient to use. Thanks a lot!
tarafından
Yorum Ekle
Try shutting down Windows from the Start Menu.
When shut down unplug the computer for about 5 minutes.
Plug back in and turn on.
Now try plugging in the USB device and see if it is recognised.
Let me know if it works.
Puan 1
1 Yorum:
Thank u for your advice but the problem still remains :(
tarafından
Yorum Ekle
Hi @jityvub
Had you tried on another computer and another USB port?
You mentioned it is a USB hard drive. Do you have model no of it?
When you connect the drive to your computer, I presume it is a mechanical HDD, do you hear any weird sounds coming out from the hard drive? e.g. some tick tick or motor spin and stop abruptly?
Puan 1
2 Yorum:
It is just a common USB flash disk.I've changed the other USB port and I can find the weird sounds but the error remains. I only have one computer can be used at this stage.
tarafından
no matter what... if data is important, if it can still be access, copy it out.
tarafından
Yorum Ekle
Yanıtını ekle
lozemyti sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 33
Her zaman: 2,597
