Ana içeriğe geç
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
iBook G3 Clamshell white screen?
I bought a iBook G3 Clamshell from craigslist for $30 from a guy who said he brought it out and turned it on for a while and after some time (forget how long) he said the screen turned just white and it never displayed normal again. The iBook does just display a white screen, so now I need to know how to repair it. I’ve looked all over but it seems no one else has this issue. I opened it up and it appears the screen cable is plugged in. I haven’t turned it on in a while because I’ve kinda given up hope that i’ll be able to fix it. But I’ve been thinking about it recently and kinda wanna fix it (even with my very very limited to no soldering skills). Anyone know what’s wrong
TL;DR: My iBook G3 only displays white screen, previous owner says he turned it on for a while then screen turned white. Need help repairing it.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Actually a white screen is positive as it’s not that serious. This usually indicates a hard drive or hard drive cable issue. I would check the connectors first.
iBook G3 Clamshell Hard Drive Replacement
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Ok, just to be clear, this isn’t the screen with the blinking system question mark folder, this is just a white screen, nothing else just white.
tarafından
You are clear.
tarafından
I'm not exactly sure it's the hard drive (or hard drive cable) because if I give it a minute or two to boot and load, and use the volume control buttons I can hear the test pattern it plays. But if the hard drive cable is taking up some more power than it should, I wouldn't know how to fix it.
Edit: I'm not a professional tho and I've heard multiple different things that could be wrong.
tarafından
I am a professional. Here's my listing on eBay for this machine: https://www.ebay.com/itm/312560467158
tarafından
The hard drive works fine. Just plug it in and it can be read from. idk how to test the cable but idk if its even broke or not
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Retro Rider sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 379
