Ana içeriğe geç
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 Soru Tümünü görüntüle
Why is my air conditioner in my 1990 accord not working
I have a 1990 Honda that the air won't work unless the windows are down and the vents are open I have tested the fuses and they are all fine
Bu iyi bir soru mu?
Puan -1
8 Yorum
You mean to say that you have to have your windows down in order for the AC to kick in?
tarafından
It don't really kick in but air starts blowing a little but it's not cold and if I put it on curculate it cuts off completely
tarafından
Okay Cale, does you fan motor work when you turn it on, regardless of air conditioning? When you turn your AC on can you see the clutch engaging and disengaging on your AC compressor? you should also hear it turning off and on? when you run your engine and then turn your AC on, do you see the clutch engaging and the AC compressor turning? BE CAREFUL AND DO NOT STAND RIGHT NEXT TO A SPINNING FAN BELT AND KEEP YOUR HANDS AWAY.
tarafından
When was the last time you had your AC system charged?
tarafından
I'm not sure I have had the car about 3 years
tarafından
3 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Well Cale, not really sure if this will help you. I just feel we do not get you to give us the information needed. Anyhow Here is the part from the service manual that deal with the AC follow the flowcharts on here to trouble shoot your AC. Good Luck
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
To make a flowchart from source code is so complicated, but I found an code to flowchart converter software, it can create flowchart from source code automatically, I got this software from http://flowchart-creator.com. It is free to download and free to try.
Puan 0
Yorum Ekle
Yanıtını ekle
Cale sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 4,462
