Time /Date are incorrect
The time and date are not correct and when I change them to correct ,the next time I turn it on it’s back to the wrong date..
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Couple things to check. Out of misguided paranoia, is your Location turned off in the Action Center/All Settings/ Privacy/Location ? Should look like this:
Also, check this - Win + R/ services.msc Scroll down to Windows Time Check if it's running and on Auto trigger.
If not, r-click/select Properties/ set Startup to Automatic/ OK.
If these both check out and you try to turn off auto sync and manually set time.
And let me know how’s everything going after that, thanks!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 356
