Ana içeriğe geç
Whirlpool marka kurutma makineleri için onarım rehberleri ve destek.
Igniter does not come on
Hi folks, I have a Cabrio Accudry WGD5600XW0. There was no heat, so over span of time troubleshooting I have replaced the thermal fuse, igniter, high limit thermostat, and thermal cut off. I have made sure there is gas and that the airflow is good. The board does not give off any errors in diagnostic mode. The igniter does not come on and I have tested all the components with a multi meter and all test fine. I am at a loss.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
When the thermostats, fuses, ignitor and flame sensor function correctly, they send a signal to the coils or solenoids attached to the top of the gas valve. These coils or solenoids open the valve and release the gas into the burner assembly. If the ignitor glows and does not ignite a flame after 90 seconds, one or more of the gas valve coils or solenoids have failed. If the ignitor still fails to ignite the flame after you replace the coils or solenoids, the gas valve may have failed, and you will need to call an appliance service technician to replace it.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Igniter does not come on at all. Is that cause by the solenoids?
tarafından
Sounds like it to me.
tarafından
@freedo my dryer is not working right I have replaced the igniter the flame sensor and the 2 coils and still not working
tarafından
@joserdelga87491
What is the model number of your dryer?
tarafından
Yorum Ekle
Yanıtını ekle
Freedolay sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 947
