No power going to hot water tank - Solved
Why would my hot water tank not be getting power
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Use a multimeter and test the breaker box then the electrical wall outlet. If it is working, you probably have a loose or disconnected wire. Great care should be taken when looking or testing for it. I would unplug it and start testing for continuity of the input wires.
Bu yanıt yardımcı oldu mu?
Thank you. It is wired right to the box
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 146
3 Yorum
Gas or electric? Make & model number?
mayer tarafından
It is electric gsw I replaced the elements and thermostat but not getting power at all.
Laura tarafından
Thank you had someone in today I had to replace the box
Laura tarafından
