Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Soru Tümünü görüntüle
New battery. MacBook turns off when charger is unplugged
I followed the FixIt guide for replacing a battery on a MacBook Air Early 2015. My older battery was having trouble keeping the charge. I let it charge to 100%, then let it continue charging for two more hours. However, after setting the energy preferences so that he Mac would not turn off in order to deplete the battery, when I unplugged the power adaptor my mac turned off. I tried everything to fix this problem (SMC reset, PRAM reset, re-installing the new battery etc.). Why is this happening?
Here are some screenshots from CoconutBattery:
EDIT 1:
After checking the battery under “About this Mac” I get the following information:
CoconutBattery is saying that my battery is charging, by my Mac itself is saying otherwise. Why is this?
EDIT 2:
I reinstalled the old battery, but now this battery is not charging either. When I disconnect the power adaptor, the macbook continues to turn off. What is going on?
EDIT 3:
I performed a SMC Reset on the older battery ( removing the battery, holding the power button for 10 seconds, re-installing the old battery, pressing the power button) and now it seems that this battery is charging. However, I did this multiple times with the newer battery and it does not charge. Thoughts?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
What color is the MagSafe LED? Amber or Green
tarafından
It is green, and on the top right corner the battery icon says 100% charged
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Lets check the MagSafe charger as you might have a bad cord (damaged) or the MagSafe connector is not making contact. Review this Apple T/N Find the right power adapter and cable for your Mac notebook and you could also have a bad/fake charger OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth & Compared- Fake vs Genuine Apple Magsafe Chargers - YouTube
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Pretty much a bad battery, if the old battery doesn't do this it confirms it.
Puan 0
2 Yorum:
@benjamen50 - I'm not sure thats the case here. I would reset the SMC to see if that altered things.
tarafından
I reinstalled the old battery, however now this battery is also not charging. I included photos in the original post
tarafından
Yorum Ekle
Yanıtını ekle
Arthur sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 254
