My lens is stuck.
I've tested the battery and it is fine. I've removed the memory card and held down the function button while turning the camera on. This hasn't solved the problem - the lens is still stuck. What else can I try?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Irene Rosko, take a look at this blog. It does describe in detail how to deal with this very common error. Should any of those steps not clear up the problem, then I would think that your issue is related to the IC that controls image processing. If it has failed you will have to replace that. But try the less invasive suggestion first. Good Luck.
Bu yanıt yardımcı oldu mu?
My. Camera is a sz1114 megapixel
Olyumpus 20x wide
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 26
Her zaman: 12,821
1 Yorum
من احتیاج به یک شارژر و یک باتری دارم برای دور بینم! باید چکار کنم؟
Mohsn Jafri tarafından
