Ana içeriğe geç
Wii U, kullanıcıların GamePad üzerinde oyun oynamasına olanak tanıyan, Nintendo tarafından üretilen bir el cihazıyla eşleştirilmiş bir oyun konsoludur. Cihaz oldukça modüler olduğundan konsolu onarmak oldukça kolaydır.
Wii U Not starting; Blinking red light
i was recently wanting to play on my Wii u for the first time in a month or so. the light tuns on blue for a second with the fan coming on then blinking red light. it has been opened recently to be cleaned. any ideas
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
J'ai ma Wii U qui affiche un voyant rouge tout en clignotant quand je tante de l'allumer, et le ventilateur à l'arrière de la console ne tourne pas. Que dois je faire?
I have my Wii U flashing a red light while flashing when I try to turn it on, and the fan on the back of the console is not spinning. What should I do?
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I know this is an old post, but if you opened up the console and removed the disc drive, be sure to plug the flex cable in the same way it was removed. You can swap the cable around and it will fit, however you'll get the blinking red light when you try and turn it on.
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
thank you!!! :)))
tarafından
Worked wonders, always try this!
tarafından
Yo estoy en la misma situación pero yo la desarme porque no me quería agarrar la sd pero cuando la desarme me pasó lo mismo pero ya le hice de todo y no encuentro la falla
tarafından
Yorum Ekle
Make sure plugs are all plugged in. Did u have a game in it? Try to get it out and try again. Or maybe you left it on last time you played which can overheat it
Puan 0
Yorum Ekle
https://www.bing.com/search?q=How%20to%2...
Puan 0
Yorum Ekle
Nothing is helping my Wii U it is always just a blinking red light I don’t know what to do anymore I try cleaning it and cooling it down I left it unplugged for over a month came back and still just a blinking red light.
Puan 0
Yorum Ekle
Yanıtını ekle
jake sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 3,177
