Ana içeriğe geç
Sony Computer Entertainment tarafından üretilmiş bir oyun konsolu. PS4 olarak da bilinir. İlk olarak 20 Şubat 2013'de duyurulmuş ve 15 Kasım 2013'te satışa sunulmuştur.
Blue light then powers off
Hello,
I’m working on a PS4 that’s suffering from a problem I’ve seen mentioned several times on here, and none of the ‘easy’ solutions have worked.
Attempting to power on, the blue light blinks for 7-8 seconds then the console powers off. Well, it seems to, but several power rails are still present and pressing the power button again in this state causes it to turn properly off. This is different to the common “blue light of death” fault where the light supposedly continues flashing until you power the console off so I’m reluctant to try things like putting extra pressure around the APU just yet.
I noticed also that the USB ports have no power present during the power-on attempt, I don’t know if this is normal, but the ports have clearly been replaced before so I’ll assume there is some fault with the USB hub controller chip or power circuitry.
Given these symptoms, is this likely to be a USB fault? Or should I try other fixes first?
Thanks.
UPDATE: The TEST signal on the USB hub controller chip is reading 3.2V which means test mode enabled. Is this ever meant to be the case? I don’t see any traces going anywhere visibly besides a probe/test point, but I realise that the signal may be going elsewhere on internal layers. I will replace the chip just in case this is not meant to happen and is the cause of a failed POST.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
A friend of mine had this problem he was told to blow the ps4 with an hair dryer for 20mins on warm back n forth because they get hot the solder sometimes melts and resets slightly off my son tried it worked as a temporary fix
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
@bev2304 I may attempt a basic reflow around the areas that could be the problem to see if it helps at all, but I understand that this is almost always just a temporary fix, and also it doesn't provide much knowledge of the fault in order to fix it properly at a later date.
I've already ordered some USB hub controller chips so I'll just try replacing that first.
tarafından
Yorum Ekle
Yanıtını ekle
Kasane Kona sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 269
