Ana içeriğe geç
Released September 15, 2008 10.1 megapixels, 5x optical zoom, 3.5-inch LCD, HD Movie Recording
3 Soru Tümünü görüntüle
Camera Memory stick locked
Memory stick is locked. not able to shoot photo, nor i can delete photos.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Is there a lock switch on the stick?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If you’re using the older style of memory card called the Memory Stick Pro, you should have a lock switch on the back of the card that might’ve accidentally gotten switched on. They look something like this (a red part of the switch will show if the lock function is turned on):
However, if you’re using the newer Memory Stick Duo or Memory Stick PRO Duo card, it doesn’t have a lock switch, and that might mean that there’s something electrically wrong with the card or camera. If you have another memory stick you can try in the camera, you can check and see if the error still shows up.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Umesh Kawalkar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 11
Her zaman: 667
