Ana içeriğe geç
A1708 / EMC 2978 — Ekim 2016'da piyasaya sürülen bu giriş seviyesi MacBook Pro, (OLED Touch Bar'ın aksine) geleneksel fonksiyon tuşlarını korur. Fonksiyon tuşlu sürüm, bir Intel Core i5 işlemci ve iki adet Thunderbolt 3 portu içerir.
Access to files on SSD drive.
Hi,
Can you please call me I’m looking for an adapter that allows me to plug in a 2016/2017 non touch bar SSD drive to either a USB-A or USB-C port to read and test drives externally.
I would need about 10 of them.
Apple Blade SSD 5GA 34+22 Pins NVMe
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sorry we don't call people - To expensive!
Sadly your model uses a very different SSD connector as you can see in this MacBook Pro 13" Fonksiyon Tuşlu 2016 Sonu Teardown jump down to Step 10.
So far no one has created one. Give OWC a call to see if they have anything thats the best I can offer you.
Your only option is to get access to another Fn MacBook Pro which you can swap out the SSD to gain access to your files.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Would installing my SSD into another working mackbook pro work exactly the same? meaning i would need the apple id and password from my SSD?
Puan 0
Yorum Ekle
I don't have 10, I had 15 made and I think I have eight left, but I would be happy to send you my PCB file, and you can send it to PCB way like I did and they can make you as many as you want, I know the design works, I've been using it for years. I designed a custom PCB adapter several years ago and had PCB Way build several of them, specifically to recover data from 38+22-MacBook Pro SSDs. They're 38+22-pin to USB 3.2 Gen2x2, so quite fast, they get the job done.
Email me.
  • Jackson
  • PhixesPhones@gmail.com
Puan 0
1 Yorum:
My above comment has the caveat of, as long as you know your password, then you're fine you can use my adapter just like any SSD to USB adapter
tarafından
Yorum Ekle
Yanıtını ekle
kirk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,355
