Why will my tablet not power on?
I have a Lenovo 58 but after using thistle a few months one day it just went off and never came back on since then could anybody help me to fix this issue thank you
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Good day, this issue is common in smartphones and tablets and could be caused by both minor and major issues. first i advise that you charge your device, if it still does not power on while on charge…you should then try a different charger and let it sit on charge for a while, if none of the above works it may be a problem with your battery , charging port or the IC Unit. i advise you to bring your device to a nearby repair shop to get it checked out and revisit this site when the problem is identified
-MCI TECH
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 119
