Ana içeriğe geç
Redmi Note serisinde Xiaomi tarafından tasarlanmış akıllı telefon.
Redmi note 4 charging issue :
1.It is not continuously charging …….after 5 min or in few min it will automatically charging stopped….after i re plugged its charging ..and again same issue.
one day its charging up to 3%. fullday it connected battery indication is glowing but at the end same 3%
what is the issue any suggestion vradhakrishnan25@gmail.com
please help me
i tried many things:
1. I replaced new battery….
2. mobile factory reset by “mi pc suite mode”
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try to resolder the USB port pins.
If you have a multimeter it is more easy to locate the problem. If you have one let me know and i will tell you where to start.
Bu yanıt yardımcı oldu mu?
Puan 8
7 Yorum:
Thank you bro .....the mobile power port pin is sometime shacking......i think it is broken..
thanks for the suggestion....
tarafından Paylaş
i'm glad it helped you
tarafından Paylaş
yes bro the issue is fixed as your suggestion .....i given to service center again ..they replaced the mobile power port pin now its working fine .......thank u bro........
tarafından Paylaş
Redmi 4 charging problem solve https://androidji.com/redmi-note-4-charg...
tarafından Paylaş
Thanks for the blog! here you will also find many useful blogs https://www.bpwltd.com/hangover-tamil-du...
tarafından Paylaş
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Radhakrishnan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 10,963
