Ana içeriğe geç
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 Soru Tümünü görüntüle
Why is my 98 sierra backfiring and burning double the fuel
I changed the plugs and wires , oil and fuel filter on my 98 gmc sierra z71 k1500 with a 5.7
I had a wire on each side crossed over somehow and drove it before seeing the problem the second time looking .
Now it burns about double the fuel and runs like it's dieing on takeoff with a load on it , not to bad without a load , but it's backfiring and spits a d sputters on takeoff and with or without a load tries to and does at times shut off when taking off at a light . Pulling up codes low air input at MAF and cam shaft position sensor, I've changed the MAF but no change .
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
reckon you may have fried or gas fouled the spark plugs at those two cylinders you had crossed? if so, those cylinders still may not be firing, meaning your power is down by 25%, and might also be dumping raw fuel into catalytic converter, impeding exhaust, etc., at the same time.
replace those 2 plugs first, i would guess.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ennis Bohannon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 287
