Ana içeriğe geç
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Soru Tümünü görüntüle
iPhone Screen is on but Black
My iPhone 8 plus’s screen randomly turns black, while using. It isn’t turning off but rather the screen just goes to a black color. While in this state I can still click things and was even able to swipe up and start playing music. I powered the phone down completely and powered it back up but the issue persists. I recorded time intervals it took to go to this and it varies dramatically. The lock screen will come on and stay on until it times out and other times only last milliseconds before going to this “black” but still turned on mode.
  • Also my home button does not work but this is an unrelated issue ( the ribbon cable broke during a screen replacement about 7 months ago), but keep that in mind when a fix is suggested.
—UPDATE: I have opened up the phone and check internal connections to the motherboard and everything is connected just fine. Then about an hour later the screen stopped producing the black screen and now produces no light at all. However, the touch pad still works (I can hear when a pass code is being typed in, but there screen appears to be off.)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Its most likely that the connector is incorrectly attached. There is a 99% chance of that being the issue. 1% chance that you have a bad part. It is most likely that you incorrectly plugged something in on the inside.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Okay I'll open it up and check it out. Thank you
tarafından
I opened it up and checked all connections. Everything was fine. Also if something was incorrectly plugged wouldn't that have been the issue when the screen was replaced 7 months ago? It has been working fine until today.
tarafından
@cjones542 The reason I asked to check for loose plugs is that sometimes those connections come loose after a while. If it's not the connections it is likely the issue is an LCD issue. Contact the company where you got the part and explain to them it is defective. They will likely replace it free of charge.
tarafından
Yorum Ekle
This might Be a mother board issue or connector as most people put on a different generation screen and then the mother board connector gets fried but you are still able to use the screen. Are you sure this is not a 7 plus screen?
Puan 0
1 Yorum:
I'm 100% positive, I purchased the screen from ifixit and the box says 8 plus. So unless they did something wrong on their end I know its an 8 plus screen. Also which of the two do you think is more likely? The mother board issue or the connector?
tarafından
Yorum Ekle
First insure that the display connector is good.If you insert iPhone 7 LCD on 8 plus the maxium chances is that the connector might be loose that causes may that issues.
If the connector is looking good in a condition check the Gnd resistance on LCD connector or might be the problem of Chestnut IC and light IC too.I also faced that same problem like you and i solved it by this ways replacing chestnut,and two light IC.
Puan 0
Yorum Ekle
Yanıtını ekle
Cory Jones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 400
