Ana içeriğe geç
Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
20 Soru Tümünü görüntüle
Power outage on my mac
i had a power outage today and my mini mac went out try to put it on not coming not start ing no light coming on nothing what could be the problem? please help dont want to lost this unit had alot of info on it thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your info is safe on the hard drive. Use a multimeter to test the output of the wall receptacle then plug in the adapter and test it next.
All you will need is a SATA to USB adapter, then plug it into another Mac to access your data:
https://www.amazon.com/s?k=usb+to+sata+a...
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
If you don't have a DVM a cheap outlet checker will do as well like this one: 3-Wire Receptacle Tester
Do make the effort to get a good surge suppressor or better yet a UPS once you get your system running to help protect it.
tarafından
Okay I check all of that but still not getting Mac mini to work what is my next step to get the Mac mini to work again?
tarafından
I would like to know how can I get this computer to work again
tarafından
You are going to have to found out, using a multimeter where the power stops coming in.
tarafından
Yorum Ekle
Yanıtını ekle
Roopram Chetram sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 141
