Ana içeriğe geç
A singing, dancing, pink pony that responds to its included toys and outside stimulus.
4 Soru Tümünü görüntüle
Head/neck very loose and clicking
When I turn it on some of the moves it tries to do it clicks. Not positive what’s wrong but when it’s turned off the head and neck move around so I believe it’s either spring or motor there. I see the information for replacing motors or springs in legs but I believe it’s the head/neck. And where do I get the parts from to replace them??
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Upon dissembling the toy, I found one of the reasons why the neck clicks. there is a small plastic tab on the tip of the black neck coupler.
this slides into the potentiometer located in the white base of the neck
. This controls the rotation of the neck and prevents it from clicking. It got broken off. I got lucky and found the broken tab when I took apart the toy and managed to glue it back it on. I don’t know if the glue will hold. If it does not I will try and scan the base and see if I can 3d print it. I will make the .STL file available if need be.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Jessica Hummell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 14
Son 30 gün: 23
Her zaman: 401
