Ana içeriğe geç
Asus Zen AiO Pro Z240IC, 4K ultra yüksek çözünürlüklü ekranı ve bir terabaytlık sabit diskiyle bilinen bir hepsi bir arada masaüstü bilgisayardır.
Asus ET2232I Not Powering On
I have an Asus LITEON WN6607AH-AD all in one PC. It is different from the one that I had to choose in the picture to the right, since IFixIt only had an option for something similar. I received it from a neighbor, and it doesn’t power on. I’ve managed to take it apart and do some diagnostics. I’ve tried pretty much everything I could think of, but it won’t boot. I think it might have something to do with a fried motherboard, which is a ET2232I Rev 1.2 board. I’ve looked online for replacement board, but it would be very expensive ($100+). If y’all have any ideas on what it could be or if you’ve had this problem before, then I would greatly appreciate your response. I’ve attached 2 pictures of the motherboard in case that would help.
Resim
Resim
Here is a list of the things I tried:
  • Installing a ram stick (already has internal memory)
  • Removing unnecessary cables from the motherboard
  • Removed CMOS battery
  • Tried 2 power cables
Bu iyi bir soru mu?
Puan 0
15 Yorum
You don't mention what diagnostics you tried.
Have you checked the power supply, for example? Is it outputting 19VDC?
tarafından
Sorry. I have 2 different power supplies and I know for a fact they both work fine. I forgot to mention that the computer on the side I had to choose is different from the one I'm working on. IFixIt didn't have an option for my model. I'll try to add more info.
tarafından
Still can't get it to do anything...
tarafından
So it is completely dead?
No lights,
no fans spinning,
hard drive does not spin,
no beep codes sounding,
BIOS can not be loaded,
etc.?
tarafından
It shows no signs of power. Not even a light.
tarafından
10 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Replace motherboard.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
1. TLDR ASUS All-In-One was not booting - just black screen.
Possible Fix - New CMOS CR 2032 battery at horrific location.
2. Background
ASUS All-In-One PC Model: ET2321I
Booting was flaky for several months. Would
halt in BIOS scrolling info, and need function keys
pressed to finish booting.
After 3 weeks of power off it failed to boot.
The screen powered on after power cord was plugged in,
but boot button failed - screen stayed dark after
many permutations of button press:
1. Short press
2. 40 second press
3. Short and long presses with power cord out, then plugged in.
3. Testing power
Ohmmeter detected about 19V DC - good.
Ohmmeter on power button (after case removed) showed 3V DC
before press, and 0V after press - seems OK.
4. Case and motherboard cover removed.
https://www.youtube.com/watch?v=pnF7c7tA...
A. Two screws under CDROM. Use paper clip to open
Plastic in CDROM hard to detach - broke small plastic
piece on second detaching.
Puan 1
Yorum Ekle
Yanıtını ekle
Petabyte Studios sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 4,860
