Ana içeriğe geç
Epson WF-2540, hepsi bir arada bir renkli mürekkep püskürtmeli yazıcıdır. 2,5 inçlik LCD dokunmatik ekrana ve dört adet bağımsız mürekkep kartuşuna sahiptir.
Why does it keep saying load paper?
The paper tray has paper in it I have tried it full of paper, with just 1 sheet or even a few sheets but when I try to copy or print anything it pulls the paper in like its starting to print then it stops and says paper out load paper then press the black or color print button so i did then it spits out the blank page and pulls a new page in but says the same thing over and over I did everything it's saying to do but it keeps saying the same thing can anyone help me?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
There is a sensor, usually a lever, that tells the printer it is out of paper. I believe your sensor is either broken or dislocated. You can find it by close inspection of your paper tray. If it turns out not to be the case, replace your pickup rollers. The pick up rollers will probably have a smooth or flat spot that causes it to spin but pickup and feed the paper late. Thus causing your printer timer to miss the pickup and feed signal.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Over time the feed wheels and sensors get coated with paper dust so they fail to work as designed.
Grab some paper towels, long stick cotton swabs, 85% or better isopropyl alcohol and a can of can’ed air.
Clean the tray and the paper feed rollers with the moistened cut-up paper towel pieces and cotton swabs. Use the can’ed air to blow the paper chamber and sensors out.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Worked great! I was ready to toss my expensive printer. Had tried everything including deleting it & reinstalling, driver and all. Thanks for some super advice!
tarafından
Yorum Ekle
Never clean rubber parts in your printer with alcohol. It removes the natural oils and dries out the rubber. Use only soap and warm water.
Puan 0
Yorum Ekle
Yanıtını ekle
Deanna Wolffe-Nicolan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 4,585
