Ana içeriğe geç
Betamax ve VHS (Video Home System) oynatıcılar da dahil olmak üzere video kaset kaydediciler için onarım rehberleri ve destek.
VHS Tape not playing.
Hi.I have a Philips VR255 Turbo Drive VCR.Everything else is working:the capstan,the motor,the drum the audio head,etc. ,but whe I put a tape in the vcr,the V Pickup arms won’t pull the tape up to the drum,and the tape doesn’t play.so I had to force the arms up to the drum (I didnt break anything,though),and the vcr played,but when I tried to eject the tape,the V pickup arms get stuck halfway and the tape can’t go back in the case,so I have to turn it off and remove the tape myself.I dont have the money to buy another vcr right now.Any ideas as to how this problem can be fixed?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I know this is from 2019 but i have the same problem, did you figure out what was wrong?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Please adjust the bigger pulley back side of v arms.the teeth of all gears must mesh properly..
Lastly but not least check the tension of the belt driving the bigger pulley and lubricate all moving
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Check to see if there is an obstruction or broken mechanism in the tape cartridge sled assembly. Sometimes the fragile plastic mechanisms will break and prevent the tape from being pulled up to the drum. Or, you might have a foreign object obstructing the path of the arms that pull the tape out of the cassette. Give the assembly a good look and you'll probably find the issue relatively easily.
Puan 0
Yorum Ekle
Yanıtını ekle
Vaughn Gracey sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 6,256
